Thermostat Gasket Sealer
Status
Not open for further replies.
62cruiserinc
I have a 1981 Mercruiser 260 with a 5.7L V8 (Edelbrock 4-barrel).
As per previous suggestions on this forum, I am replacing the 140 degree thermostat with a 160 degree thermostat (freshwater only for my boat- Lake Ontario).
I have some Permatex Aviation Form-A-Gasket (#3 I think), can I use this as a sealer for the paper thermostat gasket?
Thanks
Steve
Lou C
Yes, Permatex Aviation will work fine, you can use Merc Perfect seal (prob what they specified) or OMC gasket sealer (same thing).
Ayuh,...... Ya need a marine gasket, with the brass crush-rivets in it, or the temp sender won't work right,....
62cruiserinc
The gaskets I have are just paper, I got it from a marine store online. This is the first I have heard of a marine gasket for the T-stat. Is this something I can just ick up at West Marine? I assume the brass crush rivets are to carry electrical continuity to the T-stat cover? My temperature sender is not on the cover.
Steve
62cruiserinc
The picture below shows a variety of thermostat gaskets. The one that fits mine is in the middle, with the square notch at one side. The only gaskets that I have found with the brash crush rivets are completely round, as shown in the picture.
62cruiserinc
I see where the gasket with the crush rivets would go now that I have the thermostat housing apart. It goes between the intake manifold and the thermostat housing. The old gasket did not have crush rivets but it seemed to have a metallic polka-dot layer just like car exhaust manifold gaskets. This was probably for electrical continuity?
I can't find the crush-rivet gasket anywhere locally, so I may have to ground the temperature sending unit a different way.
Steve
Status
