I'm new to the boating world. Just picked up my first boat last year. Got to use it once last year, but started it every other week with the muffs on. Never had an issue with starting. I took the boat to get winterized by a mechanic. Then Spring came, I know the batteries are good and fully charged. Hooked the muffs on and all I got was a click from the slave/assist solenoid. I found a great article on the site how to to test everything and followed it all step by step. I found out that my two top terminals are wired different than the diagram on the site. From what I read Terminal B should be yellow with no power I think, Terminal A should be red with power (the battery), but on mine right now Terminal B has power and A does not. I want to do the jump test with bypassing the slave, not tapping A&B together. So I guess my main question would be, what would happen if terminal A&B were backwards? and if they are correct, would anything happen if I switched them?
I appreciate any feedback as my family and I are very anxious to get out with the boat soon.
