Pony
- Jun 27, 2004
- 4,355
laniganperformance.com/marine_applications.<br /><br />I know that based on the oil discussions that have occured on this board this could be considered a troll of sorts, but I really don't mean for it to be that at all. (I know nothing about oil really so sorry if this question is seems obvious)<br /><br />I was doing random google searches of my motor and found this site.(1987 25hp johnson). I am wondering if you guys have heard of this Militec stuff, and if you have does it do what it claims.<br /><br />
25 HP Johnson Outboard Engine Test<br /><br />We were receiving units that had scored cylinder walls, due to oil failure. I had acquired nine 25HP Johnson outboards from the salvage yard and put together two units as identically as possible. I set the two units in a 750 gallon test tank and ran them for four hours each, overflowing the tank as I went along to provide cooling to the engines. I sprayed MILITEC mixed with regular outboard engine oil into the carburetor for lubrication of one unit, and just regular oil into the other unit ( 1 qt each ) and ran both engines without lubrication until they stopped from lack of oil. The one using MILITEC kept running until we had to shut it off and check for lubrication in the fuel tank. I started it again and it ran for another 10 to 20 minutes. It began to slow down and finally stopped. I disassembled both units. The Militec unit did in fact offer more protection than the outboard motor oil alone. The MILITEC unit was repairable, the untreated unit was beyond repair.<br />
