The things I do when I drink
Redneckhick
I posted here not long ago about building a mini speed boat. Well the answers I received was great
and very helpful. I looked at a lot of pictures and I decided I could build a boat just as ugly as some
of the ones I saw, So I decided to start cutting on the old 73 bass boat I had.
I'm not one to waste anything so as much of the old hull will be used as I can.
I started to cut the hull in the place that it would match back up the best, but I decided that I didn't
want one seam in the middle of the boat. So after a few beers I started cutting.
bear_69cuda
Re: The things I do when I drink
Cool!
I'm doing the same thing!
Looking forward to your build!
Teamster
That thing is ready for an outboard tiller and go!!!
Pmccraney
Very cool....at least you have an excuse... A lot of us do crazy stuff like that sober...well, at least sort of... Good luck... I like it when people get creative...within reason.
Redneckhick
Well I did it again. The wife got me a 12 pack. After sucking that down I staggered out to my shop.
This is what Found this morning.
Looks like I had to move the steering to the other side to reuse the same steering. Also looks like I
decided to remove the rotted wood from the front deck and raise it up flush. It also looks like I had to
raise the transom by 1.5 inches. ( looks like I will have to drop the splash well to get the motor back
to the correct height.)
I told my wife next time to bring me a case of beer and a sheet of 3/4 plywood.P1010060.jpgP1010061.jpgP1010062.jpgP1010063.jpgP1010065.jpg
tomdinwv
"I told my wife next time to bring me a case of beer and a sheet of 3/4 plywood."
I think that is the best line I have ever read on this forum, or anywhere for that matter. LOL. How much length did you take out of the hull?
sqbtr
I want one.
What part of WV you from? ;)
Luhrs28
If there comes a time when you've had a few brewskis and decide to extend that hull look up Oops' thread.
sasto
......but you gotta be drinking Corona. ;)
I like your style redneck!
kfa4303
Banned
awesome! no way I would be that brave enough to start cutting into a hull like that, or that I would know what to do even if i did. LOL. you'll definitely what get some cool looks at the boat ramp too. what kind of motor are you gonna put on it?
tomdinwv
sqbtr, I'm in Cross Lanes, just outside of Charleston.
Redneckhick
Well she did it. After gulping down the beer I started playing with the power tools again. This is what I ended up with. The center stinger is still a little tall but should sit lower once I grind out the center of the hull. I added two shorter stringers between center and outer ones. As you can see it is going to have the shifter in the center.
