sam60
- May 21, 2011
- 3,189
I am going to the hardware store in the AM to see if they have one that only goes to 75 degrees. :facepalm:
Come on down Don, I have a lot more than that simple project for you.
I have always found the thermal coil thermometers inaccurate. Few years ago while I was waiting for correct temps to paint my car, I had one that read 120* and it's location only got a tiny bit of sunlight. Actual temp was hot, but it was like 90* hot and not 120* hot
You just moved the thermometer, that's not fair. I was meaning something like this, same thermometer, same RV. Just add a tree.
I guess I should pull the roofing nail and put the thermo back where it was. Thanks for being a good man, Don I will do my best not to participate in Nascar posts....![]()
And when we are in a rain delay to start a race, you play with the computer and make pictures easier to see.
Since the thermometer was in the dark, I just decided to lighten it up with a new method I just discovered.
Hmmmm maybe I should replace that pole with a tree trunk with bark
What program are you using for this? Would like to try it out.
