Dabbler_E
Thread starter- Joined
- Apr 20, 2009
- 338
Lurking for quite a while, and now gearing up for the obligatory transom, stringers, & deck job on a 79 Terry 450 cm, so I'm considering the great epoxy vs. poly debate
The arguments I've seen seem to boil down to:
Poly: cheaper, more than good enough given good prep, fast work time
Epoxy: stronger bonding, more forgiving, relaxed work time
What I haven't seen much of are hard numbers about how much less epoxy one would use for the same job.
Looking at the fiberglass info sticky, I see that each layer of 1.5 oz csm uses about as much resin as a layer of 1708 or 18 oz roving.
I've also read that csm is really only needed as an underlayment for cloth when using poly (not for exposy), to improve the bond to the underlying substrate & because the poly resin needs more help to be strong in multiple directions than epoxy does. If so, wouldn't that cut the resin schedule nearly in half, leading to a much more even resin budget with the two materials? Also, wouldn't epoxy allow a lighter weight roving or cloth to be used?
Hunters use conversion tables for lead vs. steel vs. tungsten etc. shot size equivalents giving similar impact down range -- it'd be great to have a similar table for epoxy vs. poly layups (e.g., what layup w/ epoxy would yield equivalent strength as a layer of 1708 w/ poly, assuming good (but not amazing) quality resins and proper prep?)
So, poly and epoxy gurus:
As an example, what would be your respective layup schedules for a 5" tall stringer on a 15' (450 cm) long, relatively narrow bass boat?
Let the games (hopefully not flames) begin!
