The Crawdad
Monterey Dreams
Re: The Crawdad
Wood,
They did not melt! I don't know what I did wrong. I covered them in a old coffee can, and poured the spirits over them.
I checked them after about an hour and the had not begun to dissolve.
Dave
Gotta run to work, I'll be back tomorrow.
Woodonglass
Honorary Supreme Mariner
Re: The Crawdad
Ok, I forgot to tell you to smash em with a hammer into as small of pieces as possible. It can take a while for em to melt into a sludge. Keep the can covered so the acetone doesn't evaporate.
Monterey Dreams
Re: The Crawdad
Here are a few photos of my repair work (in progress) Basically a test.
White patches are Attwood Epoxy Putty. Dried/ Adhered nicely to the hull. White paint is that As seen on TV crap Flex Seal. Its the one where the guy makes the bottom of his boat out of a window screen coated in this stuff.
I kinda of like it, it is spray rubber and it sticks very nicely to the Ram-X material of the hull.
Monterey Dreams
Re: The Crawdad
This shows where the holes and some deep gouges were.
More close up.
Looks like I shoved bubblegum into the hole.:D
First coat of the Rubber sealant (paint).
Texture Shot.
Well that's about it. I think it is going to work out so I am going to keep going as I have begun.
Any thoughts?
Dave:D
Monterey Dreams
Re: The Crawdad
Little more close up.
even closer photo, you can start to see texture on the rubber (paint).
A little more.
2 or 3 coats in this corner, as a test to see sealant would stick to the Ram-X material. It does.
Woodonglass
Re: The Crawdad
All I can say is, If it works...It works and I'd use it too!!!! Proof is in the Puddin!!!!
