testing on dig.ohm meter
larryg
i have johnson 20 .manual says charge coil should be 575 @25 ohms.i set it at 2000 and i got 601.sensor coil says 40 @10 ohms.i got 41 at 200 setting.its an innova multimeter.
F_R
Honorary Supreme Mariner
Re: testing on dig.ohm meter
I'd say you are right on. Well within +/- 10%
larryg
ok thanks.thats a help to my problem.engine runs fine then after a few minutes it dies.got new coils,plugs,wires and powerpak.
Sixmark
Master Chief Petty Officer
Does it just cut right out, or does it start to bog down before it dies?
Have you tried the fuel bulb trick to see if it will continue running? As this would indicate a fuel delivery issue.
larryg
it was running out of fuel.right before it died i felt bulb it was soft.pumped it and it started.so i took line off motor.pumped it.it was ok.then took fuel filter pump off ,tested it it was ok.but i tore it apart n made sure everythin was clean.cut some of fuel line off where clamps were and now it runs great and fuel bulb stays hard.
Sixmark
Good to hear you are back up and running.
