Temperature guage reads 170 deg when key is turned on
bosnbob
I have a 2007 Four Winns with a 3.0 GLP-E VP engine. I just bought the boat. When I turn the key to the run position (engine not even started yet)...the temperature guage jumps from 0 to 170 degrees. As the engine warms up, the temp guage increases to over 200. The engine and some hoses are warm to touch, but not hot. The overheat alarm does not come on...except at startup test as it is supposed to. Is there a way to test the sending unit and guages? Any ideas? Thanks
86 century
Ensign
Re: Temperature guage reads 170 deg when key is turned on
Just a wild guess but check the voltage at the gauge.
Depends on how its wired. Some the senser is the ground as the temp goes up the resistance goes down and the gauge goes up
