Keith7481
- Aug 21, 2005
- 127
After a quick search of this forum, I thought I'd post this question, which is probably pretty simple for most on this forum, but I'm stuck. My temp gauge has only worked once, I was getting ready to winterize, a muff slid and I didn't have enough water running through the system and the gauge started to register warmer. Other than that time, it has never moved. I tested the gauge by grounding the wire that attached to the sender and the qauge pegs instantly. I've just put in a new sender and thermostat. With muffs on and engine running for 10 minutes, still no movement on the gauge. I have two suspicions, the wiring is corroded (its an 87, but looks ok to the eye) to the point it doesn't register the change in resistance from the sender. Or, since the old sender was wrapped in teflon, the new sender is not fully grounded because of old teflon on the threads. I cleaned them as best I could before putting in the new sender, but who knows. I'd like to test the new sender/wiring and saw on this forum a recommendation to heat the sender in hot water and see what the gauge reads. If I were to use this test, wouldn't I want the gauge to still be grounded as if it were screwed into the housing?
