Temp sender on engine need help.........
local825
I have a 79 evenrude 85 hp, can anyone tell me if there is a sender on this engine the po was an wireing night mare, or can I run the wire from the gauge to one of the temp switches.... need help
Joe Reeves
Re: Temp sender on engine need help.........
You cannot wire a heat gauge into the overheat sensors. You need a sender such as this:
local825
thanks i will see if there is one already on the engine,if so where roughly would it be located and am i running the wire from the gauge dirrect and will it be grounded with the bolt.
Joe Reeves
The sender would be attached to one of the cylinder heads.
local825
Thanks alot.............
