Temp. fix for tilt switch
guy48065
My tilt & trim switch on the remote handle (Evinrude, Johnson 96-up) is intermittent in the "up" direction.
Replacements are no longer available so I took it apart to try to fix it. I was surprised to find that it isn't broke, solder is good, no loose or broke wires, no corrosion, no pitted contacts.
It seemed the only issue was the spring-copper "see-saw" inside was weak or bent so the rocker actuator couldn't cause it to make contact.
I tried several times to get it to work, with no success.
There is also a rubber seal inside that was in pieces so I figured even if I got it to function it wouldn't last long.
So I swapped in a momentary toggle mounted to a small piece of aluminum flashing. This was trimmed to fit the recess and held secure with a couple pieces of rubber hose to fill the space behind it.
guy48065
I hate that the only option is to replace the handle with an overpriced new one when all I need is a $10 switch.
A big reason the replacement handle is so expensive is it includes 2 new Deutsch connectors and those are very expensive--probably costs as much as the handle & switch. Seriously.
OMC should just include a 5-cent pin extractor in the kit since in most cases there's nothing wrong with the original connector.
deutsch connectors and pins are actually cheap (we use them every day at work).
nothing wront with your fix if it works.
guy48065
Cheap compared to what? The M/F 3-pin pair I just bought from my wholesaler cost me $20 (DT series). Similar weather-sealed connectors from Weather Pack or Metri Pack would have been under $5.
