teflon tape or sealant on engine drain plugs?
boatman37
so? my limited plumbing knowledge says to put either teflon tape or pipe dope on the engine drain plugs but it doesn't look like there was anything on them when i took them out. the only negative i could see from it might be a piece breaking off and getting in the engine?
What type of drain plug. Teflon tape on pipe plugs is ok, however straight thread plugs often have a gasket (oil pan, gear case, etc)
Ayuh,.... Brass plugs,..?? you can dope 'em, or not, it don't matter at all,.....
Alumarine
There's very little pressure there.
I don't use any sealant.
I just do them by hand and give them a 1/2 a turn or so after that.
If it does leak a bit it will usually rust up and stop.
boatman37
thanks guys. i believe they are brass. i removed them before winter and left them out so it has been awhile since i have looked at them. i plan to reinstall them this weekend. i don't believe there is any type of washer on them though
if its the coolant plugs, then yes, pipe plugs, most likely brass. pipe dope or tape is fine.
Grub54891
I use nothing. Pipe plugs are taperd, as long as you get them in straight, they wont leak.
thumpar
I don't use anything for the cooling drain plugs. It won't hurt anything though.
