Ted Williams water pump shooting steam!
distrbd
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]Hi all,I just joined this site (from Ontario, Canada) to receive some guidance for the upcoming repair I must do, The motor in question is a Sears Ted Williams(aka Eska) 9.9 H.P. 2 stroke,a couple of days ago I tried to run it(first time this season) and noticed the water stream that is supposed to shoot out from the water pump (or the "telltale?" )was more like steam than stream, I shut the motor off quickly and began searching for the cause, found out that the rubber impeller is the most likely culprit. so I ordered the impeller from ebay yesterday but before I throw parts at this motor I'd like to know if I'm on the right track ? I already cleaned out the water passage by blowing compressed air in the nozzle (where water should stream out) but that didn't do the trick, is there anything else I should look in to?[/FONT]
I have the owner's manual/ diagram for the gear housing assembly ,it doesn't look like a complicated repair.
Your help is appreciated
GA_Boater
Welcome, distrbd.
Were you running the motor on muffs or was she in the water? With a weak, steamy, stream, you are most likely on the right track with the impeller.
distrbd
Welcome, distrbd.
Were you running the motor on muffs or was she in the water?.
Thanks for the welcome and your reply.
It was in the water when I first noticed water was not streaming out like it did last year,I would really like to also change the oil seal ( located under the water pump) while I'm doing the impeller job but the voice in my head tells me to leave it alone lol,plus, I'm not even sure if can find that oil seal any way. being in Canada that rubber impeller cost me $50 but without it I'll not be boating so it's well worth it.
Thanks again for your help.
Ken.
GA_Boater
Hope it works and starts to spray. For some reason parts shipped across the border are costly.
