taking cap off a 85 lasar
popee1950
where can i find step by step instructions to seperate the cap. I need to replace stringers and never tried this before. thanks lee
Woodonglass
Re: taking cap off a 85 lasar
Welcome to iBoats!
First off there really isn't catch all for removing a cap. Every boat is a little different. Pics of your boat will give us a pretty good idea of what will be required. See my signature for how to post your pics. Or Create a PhotoBucket account to put them on.
Basically you will remove the rubber from the rub rail, Drill out the rivets or remove the screws whichever it is that is holding the cap. Check to see if there is any adhesive holding the hull and the cap together and detach it and then pry the two apart use some two by fours to separate the two and then have some friends help you carry it off. Pretty basic and simple.
I'm just sayin...:D
RobbyA
I have just removed my cap. You are more than welcome to take a look at my resto thread and get an idea.
My link is in my signature. There are quite a few pics also.
popee1950
Thanks i'll see if i can get pictures posted. I'll start pulling the rubber off the rail. Does the rubber just pry out?
Yacht Dr.
Hello Popee...
You also might want to start labeling and removing wires that might be tied to the deck at this point.
As far as your rubrail .. pics will help.
YD.
popee1950
I've taken the pictures will post as soon as i can. Will do as far as wires go.Need to take motor off first. I think this project will take awhile , but should learn alot and have some fun as well. Lee
popee1950
attachment.php
These are a few pictures of my 85 lasar boat. This is my first attempt at loading pictures sohope i do it right. Lee
JAFO1
Nice looking boat! Lasers were made just around the corner from my house. The good Yacht Dr. is spot on about labeling things. I'm restoring an old Skeeter. I tore into the console before I got the top off, thinking all that stuff needed to come out, it didn't. Almost all of the wires are run under the deck cap and not attached to the hull (on my Skeeter).
The rubber in the rub rail just pulls out, it probably starts at the transom.
Why are you popping the cap?
Bob_VT
Resize that photo to 640 x 480 which is the forum size
popee1950
Taking cap off to replace stringers and to check for other problems. How do you resize pictures? Thanks
JAFO1
You should be able to resize with the picture hosting service you are using. I use photobucket, it's pretty easy. Also if you use the image code next to the picture, you don't have to use thumb nails.
concept10
I've been working on removing my cap for the last four days. It's been a job! Tons of rivets. Seems some on may have replaced the rub rail before. The cap was glassed from the inside at the bow, near the consoles and at the transom. I'm still working on that area. Good luck with your project!
popee1950
Just got around to getting the cap off the Lazer. Is this doable. Think i'm in over my head. Stringers and transom. Any advice? Where to start what materials?
