corbin5754
- May 10, 2009
- 98
When I go to start my boat I prime the bulb. I raise the fast idle a little hold key in for choke and turn key it will always start but it just takes like 10 cranks and that's gotta. Be hard on my battery. It has new prime bulb vro pump carbs have been cleaned new carb gasket full tank of gas am I doing something wrong. Also when I'm priming the bulb fuel leaks out of all 3 carbs. It looked like fuel was seeping out of gaskets so I replaced all of them still leaks when priming and tilting the motor so then I checked the floats by. Flipping over carb and blowing inside fuel tube and they all were sealed. One last question when I do finally get it started it idles from 1100 to 1400 rpms back and forth where should it idle at. Thanks for your help
