rdhawk1950
- Jul 23, 2009
- 55
Re: Tahoe Q6 trollimg motor and fish finder help
When installing an after market transducer below the motor you will have problrms with false readings because there is a void between the inner liner and the outer hull. Factory installed there is a hole thru the inner liner so that the transducer contacts the outer hull. Reading install instruction will explain this.It appears in the pics that this is installed on the inner surface??
