Tachometer Replacement
weime
1996 bayliner cpri 2050. How do I remove and replace the tachometer?
Jerryh3
Re: Tachometer Replacement
Should be a bracket holding it from the back.
Remove the "U" shaped bracket and it will fall out the front. Assuming it's being removed because you think it is bad, have you actually diagnosed the condition or are you guessing?
