1996 bayliner cpri 2050. How do I remove and replace the tachometer?
W weime Recruit Thread starter Joined Apr 22, 2012 Messages 1 Apr 22, 2012 #1 1996 bayliner cpri 2050. How do I remove and replace the tachometer?
J Jerryh3 Petty Officer 1st Class Joined Sep 21, 2010 Messages 325 Apr 22, 2012 #2 Re: Tachometer Replacement Should be a bracket holding it from the back.
cr2k Captain Joined Mar 19, 2009 Messages 3,730 Apr 22, 2012 #3 Re: Tachometer Replacement Look under the dash.
Silvertip Honorary Supreme Mariner Joined Sep 22, 2003 Messages 28,772 Apr 22, 2012 #4 Re: Tachometer Replacement Remove the "U" shaped bracket and it will fall out the front. Assuming it's being removed because you think it is bad, have you actually diagnosed the condition or are you guessing?
