Tachometer/Regulator Question
cleve
Haven't posted in a while, but recently bought a 1993 Ranger 365V with a 1993 Fast Strike 150 on it. The tach doesn't work but if you look closely, the needle slightly moves when you turn the key on. I don't see a name on the tach but it appears to be original or quite old either way. I pulled it out of the dash, verified it's getting power with my meter, cleaned all terminals/connections, and turned the pole dial a few times but still nothing. The light doesn't work either. I've ordered a new tach and will return if it ends up being a regulator issue.
My question is, if the regulator/rectifier is bad and not sending a signal to my tach, would that also mean that my starting battery would die as well? Battery was fully charged after taking the boat out for a ride the other day is why I ask.
Chris1956
If the regulator does not give a signal to the tach, it is likely it is not charging.
It is an easy test. Put a voltmeter on the battery posts, engine off. Read dc voltage. Start engine and set to fast idle. Read voltage again and compare.
Voltage at battery with engine running at fast idle should be higher than voltage with engine off.
