tachometer install on 1978 800
tbonebrad
I have a 1978 mercury 800 that I bought earlier this year and the tachometer is no hooked up to anything right now. I believe I have a thunderbolt V ignition with the early style merc control. I have read posts that I need to get a harness to plug into the adapter at the front of the control. I have a question...
Is there a wire that I can just jump with to get the signal for the tach and use the bus I have for my accessories to get 12v and gnd?
If I can do this its probably just a temporary fix so I can at least tune my carbs. I have no idea what rpm I'm idling at right now and I'm worried I may be shifting at too high rpm to keep the motor from dying when I shift forward.
Barnacle_Bill
Re: tachometer install on 1978 800
That will work. The brown wire is the one you want for tach signal.
Chris1956
Honorary Supreme Mariner
If you look at the front of the MerControl, at the 3 prong plug. The tach signal will be the single horizontal slot. The verticle slots are for +12VDC and Ground.
