FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
You'll want to locate a marine tach. Test tachs have a switch on the back which will let you adapt to any type marine ignition system, outboard, stern drive, etc.
You will need a universal marine tachometer. The signal wire will be connected to the terminal block where one of the yellow wires from the rectifier is connected.
There should be a grey wire near the key switch. That is the tach signal wire.
No, a car tach won't work. You need one that gets its signal from the alternator (nearly all modern outboards)
