Tach Problems
Chieflet
I have a 1993 V4 90 hp Johnson outboard. Recently the tach seems to be playing games. It will show the proper rpm's then drop to ) then back. Someone told me it might be my voltage regulator. Is this true? Any other comments?
iwombat
Re: Tach Problems
It _could_ be your rectifier, but highly unlikely. The rectifier is just a series of diodes. They're either fried or they're good. Theoretically, one could be going out intermittently, but I'd wager large sums of money on it not being the cause. Look for a bad ground on your tach, bad power lead, or bad sending wire first.
Chieflet
Re: Tach Problems
I did those things and have not found any problems with the wiring or ground.
reeldutch
Re: Tach Problems
check for battery voltage around 3000/4000 rpm it should be 14v or a little more.
if not your rectifier voltage regulator is on its way out.
you want to replace this puppy they do get hot and might start a small fire.
