tach help
fishingonerd
I have a 1993 mercury 90 hp on a pontoon.My problem is my tach will not go to zero and just starts reading from where it stopped last time.I know it is not accurate just by the sound.It has no zero adjustment on the back.It may stop on 2 or 3000 and just start there. Thanks for your help.
seabob4
Re: tach help
What happens when you throttle down to idle, say 750 or so?:confused:
fishingonerd
Re: tach help
It still never falls below 2000 on the tach. thanks for answering
Barnacle_Bill
Re: tach help
When you turn the key on and before you start the motor it should fall to 0. If its not doing this then the tach is bad.
