Tach connection
DavidD
I have a 97 evinrude 90 that the previous owner had installed on a 87 ebbtide dynatrak bass boat. The mechanic did not connect the tach. Does anyone know what connection on the motor the tach connects to?
Re: Tach connection
Gray wire in the "engine" harness or the three pin connector right below the key on the control box.
Re: Tach connection
David, You will likely also need +12VDC (purple wire) and ground (Black wire).
