T-stat temp. range question
dmessy
1996 Force 75HP...one that came out of motor was 130 degree, got a replacement that is 141 degree. Will this make much( if any) difference in motor operation.Motor used primarily in 55-90 degree water.<br />Thanks in advance...
12Footer
Re: T-stat temp. range question
Not much, but understand it will open later,plus put more pressure on the impeller pump and water jacket.<br />If the book recommends this, fine. But if not, go with the original.
