Oshkosh1
Ensign
Thread starter- Joined
- Jun 8, 2009
- 968
SO...
I'm going to start a mess here I'm sure, but here goes.
Seeing, reading, and hearing all of the problems associated with overheating, due in many cases to faulty T-stats. Why is there a need for them in a boat which is running on "warm" water? I understand the function in a vehicle where occasionally a heater or defroster is needed...but a boat?
Can anyone tell me if they've heard or seen an I/O suffer catastrophic failure due to running TOO cool?(Although I doubt that's possible in the summer).
Would it not make more sense to remove it than to risk the meltdown of a multi-thousand dollar engine due to the failure of a $5 part?
In the hot enviroment of an enclosed engine compartment, and high power settings most boats are run at, I would think that there is absolutely no chance of a shock-cooling effect either.
I dont' run T-stats in snowmobiles just because the un-detected failure can QUICKLY lead to piston meltdown and failure. I just let them idle a little longer before taking off, to allow for warm-up.
Just thought I'd throw this out there and see how it flies!
