SyTen Helm Pump Leak
missalot
The boat I am refurbing came with a Syten hydraulic steering pump. The steering works fine except that there is a leak out the shaft that the wheel mounts on. Not only was fluid getting everywhere, but a full days use required fluid to be refilled. After finding out that there is not support or repair parts for this pump, the standard repair is to replace the system.
I pulled the helm, GOT LUCKY, and actually repaired the leak. Here is a brief explanation.
http://home.comcast.net/~e29290/syte...ump repair.pdf
richardr
Re: Syten Helm Pump Leak
http://any luck on fixing steering ...ERTIME I GO OUT ANY STEPS TO DO ??? RICHARDR
Ayuh,... Did you click on his link, it's reasonably well Explained...
richardr
http://any luck on fixing steering ... If your's is Leaking,... Where, Exactly,..??
