nphilbro
Thread starter- Joined
- Dec 19, 2011
- 304
1980 Johnson 140hp J140TLCSA
I'm not sure if this is a post about the rectifier, battery amps/voltage, or something else.
I had been troubleshooting tach problems with this motor from day one but I didn't see any posts addressing a bad rectifier until I finally stumbled across one a month into my efforts. It seemed like posts to my question were met with exactly the same answer - bad tach or it's wired wrong, set to 6p, etc. To be fair, often this settled the post even though I knew mine was wired correctly and already replaced the tach.
Anyway, I'm going to jump to the wild conclusion that I have a bad rectifier due to the fact that when I connected the send wire to to adjacent yellow wire to on the engine terminal block the tach response was instantaneous (after reconnecting the battery and hitting the ignition with a quick flick). I have an in-dash voltmeter and voltage reading on my fishfinder and neither one shows the voltage increase with increased RPMs, although I think it has dropped from 12.4v to 12.1v (maybe more?) over the course of a couple of days with many hits of the trim and some time running the bilge and radio and one harder start at the launch after I forgot to prime it. Before this weekend I had always dropped it on the charger the night before to make sure I always started with a fresh battery. I also don't recall if the voltage would climb at acceleration before getting the tach working.
The tachometer worked really well for about 3 hours on the water that first night and then *almost* all day (7 hours) the next day with numerous starts between drifting, starting (starts in an instant after carbs have fuel) again to get to new spot with intermittent episodes of running it 3200 to 4000 . As we were pulling in to the marina I noticed the tach had flatlined at 1200. I took it out yesterday and the tach still never responded and sat at 1200 just like the night before but there was still enough juice for multiple starts even when a few other issues started to come up.
1. Within a half hour I had a hard time getting moderate to fast acceleration, if not outright die, when kicking up the throttle. I could get it going, just had to ease it up yet after revving it in neutral for a few moments I could jump on the throttle without it hesitating. I didn't have this issue a week or so ago.
2. I was running an estimated 3k rpm and adjusted the trim and the motor lost power then recovered after I let off the trim (I always see a huge voltage drop with trim adjustment anyway).
3. The throttle has always been too sensitive when backing off but yesterday I backed off from 3/4 throttle to 1/2 (it's just very small movement) and it stalled out completely. It started right back up but something like that is always unsettling on the water.
My question then - if the battery isn't getting charge then what are some of the symptoms of a low battery while in operation? Am I experiencing it?
I suspect a bad contact in the remote since the first start of the day is always tough, jiggling the throttle back and forth until the ignition connection is finally made (for some reason all future starts after it's warm are easy).
Also, it idles way too high: 1200 in neutral and 900-1100 in gear (in the water) so I think the extreme drop in rpms when backing off the throttle is likely more a symptom of the timing so hopefully a sych and link will fix it.
I'm not clear what the relationship between the rectfier/battery charge/spark strength is since I thought the coils drew from the motor's ignition system independent of the battery.
One last question. Am I risking any damage to ignition components by hooking up the battery to the charger without turning off the battery switch? It's a 2-10amp charger and I know I've connected/disconnected it many times without turning off the battery but all my accessories are independent of the control box on their own circuits. I've never run the engine with the charger connected.
