SX-A, Drive will not turn prop
riegerc135
2008 5.7 GI-J, SX-A drive.
I tried searching the forums first but could not find a previous post
Hit a stump leaving a cove, drive will not turn prop. Prop shaft turns manually with prop, so I don't think I spun the hub. Prop rotates freely in both directions and drive has no clunking noises or binding, so I dont think I broke an internal shaft. Shift cable still attached and moves in both directions. Shifting into F or R with the engine off does not lock the prop. shifting to F or R with the engine on does not move the prop either direction, it is not "clunking" when it goes into gear like it used to. I pulled the shifter housing and the shift shoe is not broken. Any advice?
riegerc135
The u-joint? Wouldnt there be a large amount of noise and vibration if the u-joint let go?
dubs283
Not the u joints
The coupler between the upper/lower driveshafts inside the drive
