Swivel jack installation
am_dew
I just bought a swivel jack for my trailer -- I finally got tired of cranking the original (circa 1972) non-swivel one all the way up/down! Installation seems very simple, but does anyone have any tips or suggestions? Thanks!
Bass Tracker TX17
Re: Swivel jack installation
My only suggestions is to make sure the jack will not interfere when turning the trailer at sharp angles and re torque the mounts after a few uses. Also make sure it's heavy duty enough for your application.
am_dew
Thanks BT. The jack I bought is rated for 1000 lbs, which should be plenty for my 2000 lb 16' boat. If my tongue weight is anywhere near 1000 lbs I've got other problems. :)
Bass Tracker TX17
I can see how that would be a problem :)
Happy cranking..
Bifflefan
I would hook up your pickup to the trailer and then put down the tailgate. then install it back enough as to not hit the gate when its down.
am_dew
Great suggestion, however I pull my boat with an SUV so no tailgate to worry about.
