Switching out fuse block on Lowe boat
Wood61
I bought a new fuse block to replace old one. The new has a place to hook ground the old one doesnt. My question if I have to run new ground should it come from battery?
GA_Boater
Look under the dash for a ground buss. Nothing would work without a ground back to the battery, you just have to find it. Either keep using it or transfer the ground wire from the battery over to the new fuse block.
dingbat
Ground is just as important as the supply in a DC circuit. Daisy chaining to an existing ground connections is not a “best practice” solution.
Always run a new buss ground back to the battery.
