Switches panel
Wild b
Loking for some info switch panel for a baja 252 the switches I have worn off all the names of the switches where can I get new switch for the panel.
CaptainKickback
Re: Switches panel
Shame to replace perfectly good switches just because the names wore off. Many manufacturers make their panels so the labels can be changed. I don't know your panel, but is that possible?
Also, these are sheets of labels available from a number of sources online. Can you put new labels over the old?
Sea ya...
Failproof
Re: Switches panel
Make your own. Use a ptouch lable maker, or print them on your computer. Maybe even use one of them old school press label makers. Unless of course your one of "those" boaters who has to have everything 100% factory, in that case post pictures of what your looking for. Not alot of switch/panel makes out there so its probably universal.
