Swing away tongue not passing ground
extremez
Would it be a safe alternative to jump from the trailer to the tongue with a ground wire? Every time I lower onto the hitch the lights turn off. Even if I just lift on the tongue they flicker. I've cleaned as much rust as I can reach.
gm280
Sounds backwards from what I would say a bad ground. It would seem if anything you would get a better ground when installed on the vehicle hitch. However, There are two way to fix this. Actually more then two, but two for the most part. You could install a grounding strap from the trailer body to the area in front of the swing point on the tongue so that ground is the same with or without the tongue in place or swung out of the way. Second, and the one I like better is, install a dedicated ground wire at each light and run them all together at the hitch . And then attach the white wire from the flat plug to those ground wires and it will work every time. That way you are not relying on the trailer for your ground. And then the swing away tongue will not effect any grounding issue. But that is just my opinion.
GA_Boater
Swing tongues and tilt trailers always have the same issue, no matter how you try to ground closest to the coupler
Extend the white ground from the trailer plug past the swing joint or tilt joint for a tilt trailer and connect it to the frame - Minimum. Best is grounds to each light as GM said.
extremez
Your first method was what I meant by jumping. That worked fine. Enough to get through my 950 mile journey.
fishrdan
Yes, jump from the trailer to swing tongue. When I re-wired my swing tongue trailer, I bypassed the swing tongue and grounded direct to the main trailer frame.
Dedicated ground wire to each light....problem solved ferever
It's no secret. Any electrical connection that can be freely moved (as is the case with a swing tongue) is not a good electrical connection. Yes -- use a braided bonding wire to bridge the swing tongue joint.
reelfishin
I gave up on just grounding any part of the trailer frame alone. I simply run a separate ground from the trailer connector to each light, or at least to the main frame. Even bolt together galvanized trailers have this issue from time to time. I also solder and heat shrink all connections since I boat mostly in saltwater here.
