Swim platform brackets
ripped_78
I am installing a swim platform on my 1986 Fourwinns and I am needing some brackets. I found some aluminum ones on ebay for $40.00 a peice. I would really like to go cheaper is there any suggestions that you guys have. Can I make the brackets out of steel and powder coat them?
Haut Medoc
Re: Swim platform brackets
Your question needs to be in the restoration forum.....;)
Ayuh,...........
But,....
$40.00 is Cheap,....... SSteel will run 10X that.......
And,......
Painted, or Coated Steel is going to RUST,......... Period..........
ripped_78
I wanted to ask before I went and had some powdercoated. Thanks.
Fishermark
If you have a local metal shop - they might be able to weld you up a couple of aluminum brackets cheaper than $40 each. Just a thought. I agree with Bondo to stay away from the steel - unless Stainless.
bruceb58
Honorary Supreme Mariner
I would have some stainless ones welded up that matched your transom angle.
ripped_78
How bad would it be if they didn't match the transom angle?
bruceb58
Your swimstep would be at an angle to the water!
If your transom is vertical relative to the water line, then it is not an issue.
ripped_78
Well I never really noticed my transom to have much of an angle. I have found some that are 90 degrees I hope they will be alright.
