Swapping large V6 LU for small V4 LU
pato22
Hey just bought a four winns bow rider. Has a 79' 150hp evinrude on it
The lower unit is a mess... it is the lager style gearcase with v6 gearing (1.86:1).
It's not blown but the drain plug is stuck in(and I've tried everything), the intake screens are smashed, the water pump is probably 10 years old, they sheared off the prop nut without taking out the codder pin and destroyed the pin hole and the threads on the splined shaft... not to mention I can see some water droplets in gear oil from top plug so it either has to be changed often or resealed.
Instead of going through the process of fixing this one I have the smaller style gearcase from an 82' v4 140hp. V4 gearing (2:1) was just resealed, new intake screens, and new water pump. shaft and gearing are in great condition.
These are both 20" shaft and from what I've found they are interchangeable... 21-3/4" long measured from top of drive shaft to just under the water pump plate
But the gearing ratio would be different, the diameter of the splined shaft would be different and I would have to compensate for the change with probably a large prop to get the rpm's back where they should be...
My question is it actually doable to compensate with a large prop..? Going from a large style v6 geared lower to a small style v4 geared lower?
The motor is old and tired, wouldn't mind being a little under proped it over rev-Ing 5,500.
That way when I'm cruising at 4,000 or when I have people on the boat it won't be putting a lot of strain on the old girl
Thanks
bob johnson
the "problems" you mention are trifle...... how about the shift rod height?...are they compatible? there is a chart that explains all the interchangeable LU.....but you still have a gear ratio issue..... also I wonder if the top drive shaft splines will mate with your power head crankshaft
Honorary Supreme Mariner
Driveshaft splines are the same on those V-4 / V-6 engines.
Faztbullet
You will actually put more torque load on the lower unit doing this!!!...the pinion or driveshaft will likely fail.
jimmbo
Even though there are 2 more cylinders firing per revolution, they are of the same intensity, but I will concede they are not evenly spaced out at 60 degree intervals. The crossflow V6s with a 90 degree block and three throws on the crank 120 degrees apart made for an unevenly spaced firing order 90-30-90-30-90-30. So it will put greater stress on the gears
Faztbullet
Also the pinion and driveshaft at pinion as physically smaller...
jimmbo
But OMC did use the V4 case on some of the big V4 loopers in the 80s. Those engines probably put more stress on the internals than a crossflow V6 would
Faztbullet
That's cause they where small bore 2.7 motors and needed all the help they could get ....
jimmbo
I know the 85 V4 loopers had their share of problems, they were using the bigger case. Quite a list of mods for them.
Faztbullet
Case size don't matter...the V4 loopers has the 2;1 ratio same as their crossflow cousins
