Hey just bought a four winns bow rider. Has a 79' 150hp evinrude on it
The lower unit is a mess... it is the lager style gearcase with v6 gearing (1.86:1).
It's not blown but the drain plug is stuck in(and I've tried everything), the intake screens are smashed, the water pump is probably 10 years old, they sheared off the prop nut without taking out the codder pin and destroyed the pin hole and the threads on the splined shaft... not to mention I can see some water droplets in gear oil from top plug so it either has to be changed often or resealed.
Instead of going through the process of fixing this one I have the smaller style gearcase from an 82' v4 140hp. V4 gearing (2:1) was just resealed, new intake screens, and new water pump. shaft and gearing are in great condition.
These are both 20" shaft and from what I've found they are interchangeable... 21-3/4" long measured from top of drive shaft to just under the water pump plate
But the gearing ratio would be different, the diameter of the splined shaft would be different and I would have to compensate for the change with probably a large prop to get the rpm's back where they should be...
My question is it actually doable to compensate with a large prop..? Going from a large style v6 geared lower to a small style v4 geared lower?
The motor is old and tired, wouldn't mind being a little under proped it over rev-Ing 5,500.
That way when I'm cruising at 4,000 or when I have people on the boat it won't be putting a lot of strain on the old girl
Thanks
Thanks
