Swaping motors pulling 96 75hp force replacing with 2000 mercury 115hp
199675hpforce
Is this just a quick four bolt removal,undo fuel line then the wiring not sure about that. I have two boats both 17fters looking to keep the real clean one and put 115hp on it. Both have quicksilver 3000 controls. Is this a do it yourself project or should i spend $300 to have it done. Also are the bolt holes the same spacing im guessing they are.
4JawChuck
Re: Swaping motors pulling 96 75hp force replacing with 2000 mercury 115hp
Its Plug and Play, be safe when your lifting the motors and use a lifting eye on the crankshaft. Its easier to swap the steering controls while the motor is hanging off the transom, pulling the shaft out of the tilt tube is easier this way.
Enjoy the new powerplant!
