I just purchased a DT 100 2000 model year. I have two questions. First should my cable box ( side mount) make a beeping sound when I turn the key? The top mount control that came with the motor does. Second I am trying to turn the motor over with a battery charger. When I turn the key the starter motor spins counter clockwise but does not lift up and engage the flywheel. Is it that I don't have enough voltage and should use a battery instead. It seems when I turn the bendex by hand clockwise it wants to lift up but when it spins counter clock wise it does not.
