Swap your coils over if you can and see if the problem moves with it, for starters.
If it does you have a broken coil, coil leads or sparkplug
Post the year and model number if you can too so people can see what model you mean to help out
If it is a single coil it must be a waist spark ignition.
Both plugs fire at every revolution , one on compression and the other on exhaust.
How did you test for spark?
Inline spark tester would be the best..
Could be a bad plug
