FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
How can I tell if the tell tale is plugged or if I need a new water pump impeller. Only getting a trickle from the telltale but tons of water out the 2 holes in the back. Didnt want to risk running the motor to see if it got hot
hello<br /> the water from the 2 holes in the back is good. the tell tale on your engine will clog ith about 3 grans of sand. here we use a length of stainless leader wire and run it up the hole while the engine is running to clear them. good luck and keep posting
Wow, thanks for the quick reply. Are the 2 holes in the back the main outlet for water or does it also exit thru the hub with the exhaust. This is my first experience with Suzuki.
I have also found that an air hose will clear the lines as well. That motor should have a hot sensor (beep and the throttle) so running it submurged at 3/4 speed for 5 min should get a hot signal. If not, the thing is way cool. <br />
