suzuki DT-40 rpm fluctuations
13whaler
been reading the forums on this common suzuki problem. Its a mid 80's DT-40. Boat runs great at about 2/3 throttle , when you max it out it runs strong for bout 5-10 seconds then the RPM fluctuates drastically until it eventually stalls out...after a few tries will restart and perform about the same. I rebuilt the fuel pump, changed the quick disconnect fuel fitting. I read that a faulty water flow switch on the head could cause this problem, but the suzuki parts guy said that the alarm would sound when the switch fails and the rev limiter gets active. Is that 100% true? Dont want to change the switch($65) and risk breaking bolts if the carb is in need of a rebuild. BTW didnt change fuel filter yet...long shot. Thanks for helping Craig
cousinabe
Re: suzuki DT-40 rpm fluctuations
definitely sounds like a fuel restriction.
change that filter and report back.
does pumping the primer ball help during the high speed problems?
Mas
Gummed up carb...high speed jet?
MAS
13whaler
cousinabe ..i will change the filter and let you know thanks...Mas can the jet be cleaned without disassembeling the carb?
Mas
Nope, you gotta get into the carb. Do not be affraid, carbs are not as complex as you might initially think.
MAS
joeseif
where is the high speed needle and how is it adjusted?
