Suzuki df200ap 2021 outboard thermostat
jason stu
OEM thermostat was corroded and rotted out after 60 hours of use in saltwater installed in 4-01-25. what do you think cause is - never had that problem I replace thermostat every season
jason stu
yes, flush for 15 minutes after each use and once a month use the salt away attachment with hose.
99yam40
is that with motor running to get the stat open and fresh water circulating thru the open stat?
boscoe99
Was it OEM? Just saying, that cheap China junk is out there..
"OEM thermostat was corroded and rotted out after 60 hours of use"
We love the prices of cheap stuff no matter where it comes from. Then biitch about the quality rather than buying higher quality foreign made parts.
jason stu
was OEM $62 - Suzuki parts come from Japan-
99yam40
and still you have not answered my question about if the motor is running to heat things up to open the stat while you are flushing with fresh water.
or maybe that yes was confirming you do run the motor while flushing
