mudcatwilly
Thread starter- Joined
- Aug 11, 2006
- 32
I have a 1990 Suzuki DT 2-stroke (85 hp). Today when I took it out on the water, I would have the throttle set at maybe 3/4 full and all of a sudden, I would hear the motor rev and the boat would slow down. It was like all of a sudden, the gears weren't catching to spin the prop. I moved the shifter back and forth a bit, then the prop would catch and the boat would cruise fine. For what it's worth, on the way back from fishing, I set the throttle at 3/4 full again and it ran great. Has anyone had a similar experience with this type of motor and if so, what may be the cause? Also, the shifter is a bit touchy. In reverse especially, you can hear the teeth of the gears clack unless you really slam it into gear. It does it a little less so when you first shift to forward. Please help!
