Im fixing up a motor for a relative of mine, its a 1974 johnson 15horse. It has sat in the barn for probably 15 years now. First thing I did before starting it was pull the carb and clean it out and checked for spark. Everything checked out fine so I hooked it up to muffs and started it up. Surprisingly it started up, idle was a little off but it purred nicely for sitting for so long, though it wasnt pumping water. So I ordered a new water pump and carb rebuild kit just for insurance. After replacing the water pump, the thermostat, and doing a carb rebuild im where im at now. Tried to start it up last night but no go. New plugs and very strong spark. It turned over once with a little starting fluid (yes I know starting fluid is bad to use, i only used a tiny bit to hopefully help pull new fuel through the lines), but after that nothing. With as strong of spark as its getting i dont know why it wouldnt fire on starting fluid? Im kinda lost on what to do next. I pulled the flywheel and the points are clean and set properly, I was told the points where changed before the motor sat. I know there is a mark on the cam that is supposed to line up with the roller at some point. I just dont know when or where thats supposed to be. When in neutral and I turn the tiller as open as it will go, the mark on the cam is to the left of the roller. (IE, when the tiller is as slow as it will go the mark is very far to the left of the roller). I dont think this is right from what ive read but im unsure. Any help would be greatly appreaciated.
