ehenryfair33939
Thread starter- Joined
- Jun 17, 2023
- 2
I have a 1993 stratos bass boat with the original trailer. I came with the Sure Lube spindles. They use a dust cap with the zerk fitting made into them. You pump grease into the cap which forces grease through the outer bearing filling the cavitiy in the middle then pushing grease through the inner bearing and then its hits the seal and its forced through two small holes on each side of the spindle and out the back of the spindle. Problem I am having is there seems to be a collar on the spindle that the seal rides and it slightly turns on its on and blocks small passages. So that when I try to add a couple of shots of grease to the hubs it pops the cap off. I cannot find any info anywhere regarding this collar. I can spin it back in line so that the grease will pass through the hub but of course I have to take it all apart each time I lube that hub. Any help would be greatly appreciated.
