Little niangua
Thread starter- Joined
- Jun 5, 2005
- 1
I have this 125 hp force engine built under Chrysler ownership 1984 model. I am used to seeing two similar sized oil service ports on the lower unit. On this engine I see the two similar sized ports up high and a smaller screw down low where the drain and fill plug should be. The last time I pulled a small screw plug down low it was a pin holding something in place. Never did get it back in. Please... the drain refill proceedure for the lower unit oil. thanks.<br />Little
Nianagua
