Mnoverboard
Thread starter- Joined
- Sep 14, 2014
- 51
Hello all, I'm stumped. Here's the problem.. When shifting into forward there is a NOTICEABLE delay (2seconds) before I feel the drive engage. Reverse engages without any issue. I believe the controls are teleflex SL-3 side mount with trim. Here's the facts...
With the shift linkage disengaged at the drive and the prop in the water, I can shift it using my HAND into forward/reverse like butter.
Attempted to adjust at the linkage but is already adjusted to the max
Replaced shift cable - same issue
Placed a 3mm shim in front of shift cable retainer on the drive so I could gain some threads and adjust the linkage. This solved the problem for most of the season... But now it's back. Two second delay when shifting into forward. Reverse no prob.
Outdrive oil is at proper level and is pristine.
I'm starting to think issue is at the controls. It's seems as if the whole assembly is set too far towards the reverse side of things.. But there doesn't seem to be a way of adjusting it at the controls. Any help would be appreciated as I'm starting to lose my mind lol. Thanks in advance Patrick
