stuck in gear
pletz90hp
I changed the impeller now prop does not turn freely now what do I do
pletz90hp
I didn't take nothing off but 5 volts ..90 go Mercury Mariner engine
pletz90hp
When the lower unit is off of the 90 horsepower the propeller still don't turn freely
flyingscott
90 hp WHAT 6 cyl/3 cyl and 2 strk/ 4 strk . I would guess when you took the lower unit off it slipped into gear. There is a FAQ at the top of the forum that tells you how to assemble a mercury lower unit back on the motor.
fhhuber
You probably moved the shift lever while changing the impeller then didn't get things adjusted properly putting the shift linkage back together.
Depending on which engine there will be one of about 3 fixes to get it back into adjustment, just a matter of knowing which engine to give you the correct fix.
