Rockriverine
Thread starter- Joined
- Feb 11, 2013
- 20
I just pick up a 56 Johnson 30 hp and am resealing the lower unit.
The pivot pin head was stripped. Prior owner sealed around it with some type of calk, but looks like
he was not able to remove and damaged it.
I sprayed it with pBlaster let is soak and put some heat to it.
I tried to use a drill back-out tool and no such luck.
I'm afraid to do much else with it for fear of mucking it up more.
If I drill the head off to remove it, can you get a vice grip on the shaft from the underside to get the threaded end undone?
Appreciate any help.
Steve
Steve
